Spin not working
Hello.
Okay spin stopped. Adjitation is fine. Motor turns left stops and turns right for Adjitation. Water drains then…nothing…if i wait( note machine tipped back slightly so I can see…bottom servicable…) then motor will turn for maybe 3 seconds…belt is NOT grabbing…If i Shake machine tub will start to spin…i have ordered a belt…ouch pricey…my question is…once belt is replaced could there be a potencial secondary issue that would add to the no spin?..wifes friend called and said now no drain…before drain time was satisfactory…yet i did not check the pump for obstructions at the time since the machine drained fine. any insite is appreciated …i would rather attack this with more parts than i need…then to have to go back…happy wife happy life (:
not sure what trackbacks are?
