My washer broke the other day. I determined it was one of the springs that hold the drum up, and replaced that myself. I looked around for signs of anything else being damaged, didn’t see anything, and put it back together.
When I attempted to do a load of laundry, the washer filled with water but did not spin. After using Google to search for similar problem reports, I found out how to put my "Good" model washer (not "Better") into diagnostic mode. My problem now, besides a broken washer, is that I can’t decipher the cryptic beeping codes (even with a key).
The 5 lights beep and flash 5 times, along with the start light at the same time, then the start light flashes 4 additional times before pausing and repeating. I thought this would be error code 54, but there isn’t such a thing.
Any ideas?
