Squeaky Dryer
My Dryer is making a squeaking noise and I am trying to find out if this is the v-belt and if it is something I can fix myself.
Probably bad drum support rollers, or a bad idler pulley. Pull drum and check. Usually, the rollers will need to be replaced. Be sure to use non-detergent oil on these.
