Squeeky dryer
I thought a couple drum rollers might fix the horrendous squeek coming from my dryer but after replacing them I am looking elswhere. The belt appears to me a little worn as a few strands are coming loose but with a flashlight im guessing the tensioner pulley might be the real problem. Or possible a bearing somewhere. Any ideas??
Hi.
Most likely it’s the idler pulley and the shaft.Check if you need both , then order pulley and arm.
The other possibility is motor bearings.
Here is the breakdown diagram http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45482&diagram_id=28472682
Thank you. Post the results.
Simon.
