Whenever I turn my dryer on it starts to make a loud squeeling sound and last until I turn my dryer off. The drum turns fine, the heat is fine. What can I look for in repairing this horrible noice?
Hi Mathew
I cannot get your model to come up, but your noise is likely from the drum.
Take off the top and try to turn the drum manually to hear where the noise is coming from. It is likely from the back where the drum is supported.
yes, I already took the top off and did spin the drum manually and the noise is coming from the back. This is where I get stuck, I don’t know what to check or replace after that…thanks
ok, thanks…i’m going to work on it this weekend and i’ll let you know
