Hi,
I have a stackable washer/dryer, whirlpool and serial # MK5131921in my condo unit. My tenant called me up and said that it’s not heating up, Does anyone know what that could be from? and How much? Thank you
Hi,
If your heating element is good, it’s probably item 15 or 5 on the diagram (thermostat or fuse). A cheap $2 ohm meter will tell you which one.
Dryer bulkhead replacement parts for WHIRLPOOL LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM | AppliancePartsPros.com
I would check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If you are unfamiliar with electricity then get a pro in to check/fix the unit.
