At first just the quick wash button wouldnt work, so have just been using normal wash, but today I loaded my dishwasher and the start button when you shut the door will light up but will not work when pushed, what could be wrong with it???
Hi.
Unplug the unit.
Remove the control panel.
Disconnect the flex ribbon from the control board and using pencil eraser clean the contacts.
Reinsert the ribbon and try if that helps.
If not - replace the control panel.
The control panel BLACK W10101960
If itβs not black reply with correct color.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136239
Thank you.
Simon.
