Stash
My Whirlpool Cabrio dryer seems to over heat and puts out high temps no matter what the temp setting…high , med , or low .
I’ve checked the whole vent system and the blower , as well as the inside of the cabinet and have found no problem .
Is there a temp thermostat or temp control which may have gone bad and needs replacing ?
thanks
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED6200SW1
Yes there is a thermistor that can be checked, see the tech sheet.
The first thing I would check for a grounded element.
Unplug the unit and both wires from the element.
Measure across the element, should be 8 to 12 ohms.
Then measure from each side if the element to it’s cas, both should be infinite ohms.
If not the element is grounded and should be replaced.
thanks for your help and tech info , Denman .
Stash
thanks for your help and tech info , I’ll check the heating element for grounding .
Stash
— Begin quote from Stash;873702
Stash
( this looks like more than 10 characters to me , but the website keeps kicking it back to me ! )
— Begin quote from Stash;873701
Stash
I’ll check the heating element .
Stash
