stops in cycle
The unit begins as normal, however a few minutes into the cycle it will quit. A slight pressure on the door will restart and continue. In my case it followed through the whole cycle, however my wife claims it quits again and requires additional pressure. Is there an adjustment to the door I can perform or does the switch need replaced?
