Superba ice maker motor replacement
I need to pull out the ice maker and replace motor housing attached to the left side.
I noticed their is a clip on the left underside that releases but am not sure how to release on the right side. Is there another clip on the right side to release the assemby, if so where is it located?
— Begin quote from borgo1;293592
Borgo,
I think this is what you want or need.
Good Luck,
[FONT=ArialMT][LEFT]1. Disconnect the unit from the electrical
supply.
2. [/FONT][FONT=Arial-BoldMT]To remove the ice maker:[/LEFT]
[/FONT][FONT=ArialMT][LEFT]a)Open the freezer door.
b)Close the spring-loaded emitter door[/LEFT]
and open the ice maker door
[FONT=ArialMT][LEFT]c) Push the ice maker door to the left so
that the right pin disengages from the
pivot arm, then lift the pin out of the[/LEFT]
pivot, and remove the left pin
[FONT=ArialMT][LEFT]d)Remove the wire shield screw from the[/LEFT]
bottom of the ice maker
[FONT=ArialMT][LEFT]e)From the rear of the ice maker, lift the
top of the wire shield slightly and pull it
back to release it from the ice maker.
f) Press up on the two retaining clips (one
on each side) at the bottom of the ice
maker tracks with a fingernail of each
hand, pull the ice maker forward, and[/LEFT]
remove it.
[LEFT]g) [FONT=Arial-BoldMT]If you are completely removing the
ice maker,
[/FONT][FONT=ArialMT]unplug the wiring harness[/LEFT]
connector from the ice maker
[LEFT]h) [FONT=Arial-BoldMT]If you do not want to completely remove
the ice maker
[/FONT][FONT=ArialMT]rotate the ice
maker so the square end with the motor
faces the front, and hang the flange
of the ice maker on the track that is attached[/LEFT]
to the freezer mullion
[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
