trying to separate outer tub from transmission to replace tub seal
I have got down to the point in disassembly of a top load washer/dryer combo and am stuck as to what to do next. I have taken off everything I need to so i seperate the washer tub from the motor/transmission assembly but it isn’t coming out like you think it would. Any help and suggestions would be greatly appreciated! I will also add in more detail if it is needed. Thank you in advance!
