Tub won't spin unless you open & close the lid
I’m not an appliance guy, but I dabble in troubleshooting…I’m not buying into the timer cure-all solution presented here. I mean, haven’t clocks been around for a millennia or two? I want to assume humanity has mastered the clock by now.
In my case my washer was recently repaired for making a clunking sound during agitation…it was only AFTER the appliance guy worked on my unit that I started having issues with the spin not engaging. In addition, the unit makes a strange hum noise when it is supposed to be spinning but isn’t. I have also observed what sounded like a shot of water being introduced during the spin cycle, which I honestly assumed should not be happening…this was the only potential symptom I observed that MAY be related to the timer. Even then that could be normal, and I still wouldn’t suspect the timer hardware if it were abnormal… I’d suspect the numb-nuts who botched the repair that caused this issue. Perhaps the timer can be calibrated?
shmoozer said:
Well, any feedback? Mine is doing the same and I did clean the contacts inside the timer several years ago. I cleaned them again; only one seemed burned. I have a 11092583810 Kenmore Washer. The cheapest timer I found was on (withheld) for $89 but now I’ll check this site for a price. I would rather just replace the contacts if they can be purchased. Can I buy just the contact pack for the washer instead of buying the whole timer?
I’m sorry for the late update. My issue turned out to be the speed control selector switch. Somehow, playing with the lid and controls would make contact inside the switch. Pushing on the knob of the speed control made the connection. I ended up purchasing a new washer last year- what a mistake.
It is a Belt Drive machine… not a direct drive. Does this change things?
and BTW… I cant open and close lid since it stays locked throughout whole wash cycle. So any other ideas…
and lastly… it is a 2014 Whirpool New style Belt drive.
sidfink43 said:
I am assuming this is a direct drive Whirlpool made machine.
Your machine has a neutral drain, meaning when it starts to drain the transmission shifts into neutral so it is not trying to turn the tub while it is full of water.
The timer needs to pause the motor after the drain is complete. This causes the transmission to shift into spin. If the motor does not pause, no shift. So the timer is not doing its "pause" job, and when you open and close the lid you are doing the pause job for it. That is why it starts spinning after you do that.
So replacing the timer should fix your problem.
and lastly… it is a 2014 Whirpool New-style Belt drive.
My warranty company is sending an appliance dude back out…I’ll remember to post whatever he tells me but I’d take it with a grain of salt considering he either 1.) he put it back together incorrectly. or 2.) failed to test thoroughly.
