Visibly damaged heating element in Jenn-Air oven
Hi, the lower baking heating element has failed in my Jenn-Air oven and I’d like some advice on what might be wrong. Roughly 1/3rd of the heating element appears to have overheated (sort of a bubbled/rough look to it) and deformed enough to bend down to touch the oven bottom. The broiler looks okay and does work.
Is this most likely just a failed heating element or some sort of temperature control problem?
It’s a Jenn-Air JDR8895AAS Dual-Fuel Double Oven Range (only the bottom oven is affected).
thanks so much for any help with this!
