our Maytag washer vibrates so bad on the spin cycle, it walks across the floor!!! it is level
Hi Moses
Can you post the complete model number, there are a lot of Neptunes out there and we need to know which one you have
Thanks for getting back to me! the model no. of the neptune washer is MAH8700AWW . Thanks again, I will be waiting to hear from you.
Ron
Ok, Thanks
You are going to want to look for something loose in the pulley or the suspension. Start with taking off the back and testing the pulley for tightness.
Here is the service manual which will help you take off parts of the cabinet and look at the other components.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Good luck.
Thank you for all your help!!! Take care,
Ron
