washer agitates while filling
My washer started agitating while the machine is filling with water. Can’t stop it. What could be causing this to happen?
Check out the water level switch, but it may be the timer.
I cannot get your model number to come up, so please check it and re post if you need more info.
— Begin quote from sidfink43;445490
SEE BELOW MESSAGE
I looked on the machine. Model number is WTW58ESVW
