WASHER DOES NOT SPIN OR AGGETATE
motor turns freely without belt. motor will turn and burn pully and belt transmission does turn but not very easy
water pump ok not locked up
if you take belt off turn motor on it works fine
do you think maybe trans is bad
If you can not move the drive pulley in both directions by hands then the transmission most likely is bad.
- The transmission AP4373431
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177904
the drive shaft pulley
if I pull the belt off i can turn the transmission pully it does turn but it feels slugish
so if i put it on a cycle it will fill the tank then when it goes to aggetate it locks up and pully on motor spins and starts to melt belt and pulley
if I advance the cycle to rinse it will drain so motor is turning and belt is turning or water pump wont drain tank
I just cant get it to aggetate
Can you turn the drive pulley clockwise? If you can not then the transmission is locked up and has to be replaced.
will try tomorrow
Thanks for the info
