Wife said washer was leaking water on the floor. I check for leaks at back of washer and found none. Must be inside of washer but I need help on how to take it apart and what to check…Thanks for and input
— Begin quote from atucker2;285908
Is this a new problem? Most common mistake is using too much soap.
