Washer leaks. Replace pump? (Belt drive. Old unit.)
This unit leaked once, then worked fine, and then leaked nastily. The leak started as it was filling, at about half-full. Then, even shut off, it leaked down to a couple inches remaining. It would not drain when I selected the drain/spin cycle.
My questions:
  1. I suspect the pump. Shall I replace the thing?
  2. Anything else I should replace while I’m under the thing?
  3. This unit does not have a removable cabinet, just a rear access panel. I think this site has directions that make sense (loosen belt from rear, then lean the unit against the wall and go under it). You agree?
    http://www.applianceaid.com/belt_pump.html
PS: Anyone know how I can buy the Whirlpool washer repair manual from this site?
Thanks!
Thanks, I can try that. But: why tilt it forward? And: how much should I tilt it?
Given that it couldn’t drain itself, I’m inclined to suspect that pump, however.
