I have a Whirlpool Super Capacity Plus washer. It leaks. Until recently, it leaked during use. Now it may be leaking all the time. I haven’t found the model number. I have had it upside down and the parts are not very accessible, if that helps. I don’t see any belts.
I’m wondering if this is likely an easy fix or if I should just bag it.
Most likely the problem is a bad pump. In order to provide more accurate advise we need the complete model number of the washer. You can find it under the lid.
