My Whirlpool Washer Is Leaking Water Behing The Whirlpool Pump Assemble… The Water Looks Like Its Running Down The Motor Shaft… What Do I Need To Fix This Problem…ps It Seems To Leak More When The Washer Is Filling Up…and Just Drips After This Is Completed…
Most likely the problem is a bad pump. The correction is to replace the pump. The instructions are attached to the reply.
- The part number for the pump is AP2907492
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=83235&&model_id=257120
