Need instruction on how to replace the water pump. I was told that the leaking situation when the machine fills with water and empty the water might be the pump is bad. Need to know how to replace the pump was told it was easy.
Related topics
whirlpool washer leaking | 2 | 2031 | May 18, 2009 | |
washer is leaking out bottom | 0 | 2506 | May 10, 2008 | |
Whirlpool washer leaks | 7 | 2488 | June 9, 2009 | |
Washer leaking when filling up | 3 | 3161 | November 2, 2009 | |
Washer | 2 | 1701 | June 9, 2010 |
