Water is leaking out when filling up, so I believe is a gasket or something like that. Can someone help me with info on how to disassemble the unit to find the problem.
Thanks in advance
Drepair
[SIZE=3]This is a page on how to dissemble a common Whirlpool direct drive washer such as yours http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Take a hard look at the water pump because it is the most likely thing to leak. [/SIZE]
Thank you. Something went in the pump and crack the housing.
Drepair
