Whirlpool washer leaks
I have a Whirlpool washer that leaks only when it is filling the tub. How do you remove the cabinet? Thanks for any help that you can give me.
The first thing I would check is the pump. This is a good time to check the motor coupling and replace it if needed. You can find the instructions attached to the reply.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=116012&&model_id=265335
You are welcome. Keep us posted.
— Begin quote from Gene;90667
I replaced the pump and just finished washing a load of clothes. I did not notice any leaks. It was not a difficult job. The information that you provided was very helpful.Thanks again.
We are glad you were able to fix it. Good job!
i have the same problem. if you get any help, please pass it on to me. thanks
— Begin quote from modelshop8624;88571
— Begin quote from fredazz;95371
I removed the pump and that solved my problem. good luck.
