the washer spins and turns the pulley but the pulley just spins and doest spin the tub.
sidfink43 said:
OuchIf it is not making any noise and the motor and drive pulley are spinning freely the problem is likely in the transmission.
Here is a service manual you can look at to see if you want to attempt a repair, but given the complexity of that you may want to look at a new washer.
http://www.servicematters.com/maytag_library/docs/RS3100004R1.pdf
Good luck, let us know what you decide.
I guess what your telling me is that the pulley has nothing to do with the spin cycle? If so I guess I’ll look at another washer. I’m sure a transmission is expensive.
