washer not draining
[I]the washer doent seem to drain properly, i clean out the pump.It seem to work for awhile, but now it seems to just drain once in a while. the code f1 and 5d comes up, and the pump seem to be hot.but stops spinning and draining…thanks any advise would be of great help.
thank you Hete beste Chris
[/I]
You should have found a tech sheet inside the lower service panel which explains the error codes to you and explains how to put the machine into a diagnostic mode.
Concentrate on the water pressure switch and the main control unit.
