washer not filling...
Hi everyone,
So all of a sudden my washer won’t fill. I’ve checked the screen, hoses, inlet water and they are okay. I’ve pulled out the water valve and both the hot and cold valves don’t seem to let water pass when I turn on the washer cycle. I’m thinking it is highly unlikely that both valves failed at the same time, so perhaps there is a common interlock that has failed…any ideas?
TIA
indy
I should say that the washer works on spin…so power is okay…and doesn’t fill on cold, warm, or hot.
The unit has sat for years it has few hours on it. when i pluged it in it wouldnt cool. i ran it over night and it would make a light frost on the top of the coil but thats as far as it goes the rest of the coil is lightly cool. i thought it may be low on freon. but i was told it was the temp control.
does this sound right or would someone have an idea of what i should check. the compressor runs and sounds good the fan inside runs and seems to blow well.
Partial frosting means low freon. A faulty temp control would not cut the compressor off when the proper temp was reached or it would cut the compressor off before the proper temp was reached.
