washer will not fill
Need some help please.
Washer will not fill,(clod or hot) Replaced temp seletor switch and fill valve.
Temp Select switch seemed touchy at one point. thought it my be that.
Then maybe fill valve.
Can it be the timer and switch combo??
not much more to consider.
thanks for your help
Bill
Check to see if 120v are going to the valve assembly when it is supposed to be filling. If not, the problem is likely the timer.
