Washer not spinning
Washer begins to spin, but stops only after 2 - 3 seconds. The belt is intact, but shows normal wear (some cracks etc). The tub is not out of balance. It keeps trying to start the spin cycle after a few minutes but stops. Any help is greatly appreciated!
I replaced the belt. Initially, the machine kept stalling. It took 4 or 5 tries before it kept spinning. We’ve washed some loads. It works OK but the motor seems to run hot. I’ve never actually witnessed the motor when it runs so I don’t know how hot is should get. Please advise and thanks for help.
Hi Dale,
Open the control panel and remove the wire plug for the low voltage transformer from the control board. Check for 120VAC between the P16-6 & P16-7 terminals (where the transformers Red wires connected).
If there is nothing wrong then check for 20VAC between the P16-2 & P16-3 transformer terminals.
If there is nothing wrong then replace the control board.
Here are the break down diagrams for the Whirlpool oven/microwave combo http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=112202&&model_id=263931
Dale,
Which part did you replace? Control panel and touch pad is the same part.
