Washer Spinning Not Working
During the spinning cycle, water is being discharged but it is not spinning. During the spin cycle, a buzzing/grinding sound can be heard from the bottom of the washer. Any suggestions?
I had the same problem. Look under the washer you’ll probably find a small pile of shredded black rubber. If so, its the direct drive coupling. New part is about $12 + shipping. Remove the shell, disconnect the water pump and motor. Install new coupling (3 pieces). New improved parts did not fit smoothly. I had to gently tap them with a hammer to fully seat them on the motor and gearshafts.
I have similar problem. I just finished working with mine. Some screws will need drilling out because too tight. Tried WD40. Lock light does not come on and motor latch does not operate. Pulled oven halfway out. Not worth the trouble. Latch cost over $100. Will probably replace whole double over. Over 10 years old.
