Our washer will stop in the middle of a cycle.When I unplug it and let it set I hear a click from behind and plug it back in and it starts again. Is it a relay going out? Any help would be appreciated. Thank You
Thanks Gene for replying.I had a load stop again and I tried tapping on the
water level switch and nothing happen,then I push the main control in turned one click and pulled it out and the washer started. What do you think. Thank You
How can I fill the oil in the gearcase,what kind of oil and how much do I have to fill?
How can I change the seal in the gearcase?:rolleyes:
You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros.com/washer-repair/4929-transmission-oil-fill.html
Thanks Gene, I´d like to know if is possible to add oil like 15W40 (for cars) and if is easy the change of the rubber seal. I´m planning to add the oil through this seal, avoiding the removal of all the parts. Do you agree?
Thanks again
I would not risk with oil not recommended by the manufacturer. You can add the oil by removing the oil seal (#21 on the [B]AP3043580.
- The part number for the oil seal is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3043580&&&model_id=5141661&diagram_id=940399)
