Washer Unplug and wait a few seconds then plug in and power is restored.
I remove the plug from the outlet, wait, then plug back in. When I plug it back in the machine powers on. It runs fine through the cycles. When it finishes I remove the clothes and put more in and it works well. If I let it sit and come back to it later, it will not power on, If I unplug and plug back in it will run again.
I have had an electrician check all my outlets and for dirty electricity, nothing was found. I’ve had Whirlpool tech out several times, everything tested well. Control board has been changed, voltage check done, breaker reset.Power cord replaced. He even put a filter on the new power cord to help clean the electricity.
Nothing seems to be working, my washer still will not start after it sits a while. But, as I said if I unplug, then plug in, it will work again.
