Washer will not spin but drains and washes
My Kenmore front load washing machine fills, washes and drains fine however it will not spin. I do notice the the lock light does not come on in front even though the door is looked when washing. Can you help?
Hi.
Take off the top and the toe panel. check the harness and connections from the door switch to the control board.
Disconnect the plug from the control board and using the multimeter check continuity (door closed) at the door lock contacts.
You should read continuity between BK and OR, RED/BLK and
BLK.
No continuity - replace the door lock.
The door lock [part]AP4455026[/part]
Thank you. Post the results.
Simon.
