I have a Kenmore (Whirlpool) washing machine that will not spin. It just sits on the spin cycle and buzzes. I had a tech come out and dianosed a bad motor. I ordered a new motor from appliance parts pros. Installed it and recieved the same result. I called customer service and a new motor was sent out to me. The second new motor was installed and does the same thing. Is it possible I received two bad motors or should I be looking at something else like a switch, timer or relay?
Did the tech test the lid switch? It could also be a bad start capacitor. Disconnect the motor from the gearbox and see if it runs while disconnected. Make sure no wires are crossed or touching any metal as you do this.
The lid switch is working because it will not to anything unless it is pressed. The motor has been off during the test. The motor also has a connector to only connect one way. Is the starter capacitor located on the motor or somewhere else?
On some of the older models, it is attached to the inside of the rear panel. The newer machines have them on the tub support near the motor. Test it by pulling the motor off the machine, but leave it connected to the wiring connector. Select "spin". The lid switch has to be closed. If the motor doesn’t immediately start, give it a little assistance by turning the shaft (be very careful: You’re really close to 120VAC. If the motor does start on its own, replace the capacitor. If you have to help it, replace them both.
I found the Capacitor. Our local shop has one in stock. I have 2 "new" motors on hand so I will give it a shot. Thanks for your help so far.
— Begin quote from jroske;191386
Installed the capacitor and the motor will just sit and buzz on the spin cycle. Agitate cycle does work. Could the timer be bad? What are the odds of receiving 2 bad motors?
Very slim odds of two bad motors. There’s gotta be something we’re missing…Can you freely turn the gearbox shaft in the spin direction with the motor disconnected?
— Begin quote from magician59;191415
All three motors (1 old, 2 new)turn freely but there is more resistance when I attempt to "spin start" it with the power applied. Could the switch be bad?
I was referring to the shaft on the washer. If the motors work while uncoupled from the machine, the trouble is in the gearbox.
— Begin quote from magician59;191613
The motors will not start while they are off the machine with the timer in the spin cycle but will engage most of the time in the agitation cycle.
Sounds like the timer has gone bad. If you know how to read the timer chart in the Tech sheet, you probably can test it with an ohmmeter. Otherwise just replace it.
- The timer AP3965586
Then the problem is probably in the timer.
my ge profile is not cleaning glasses or anything in the upper rack properly. The lower arm is turning but not the lower. Seems to be plenty of water in machine. I cleaned lower arm assembly and filter and blew through the delivery tube to the upper wand . any sugestions Gary
— Begin quote from gary wulfhop;386131
Gary,
The most common problem for your complaint is, not enough water in the tub, to properly pressurize the pump and circulate the water.
There are a couple of "general" ways to check for the proper fill.
a) when you start a wash cycle, there should be a few seconds of pause,
between the end of the fill cycle and the pump motor start and circulation.
b) let the dishwasher start, fill and run for 3 to 5 minutes, then unlatch the
door and wait a few seconds and open the door and check the water level
in the bottom of the tub, on most profile dishwashers, the water level
should cover the bottom filter screen, and at least reach as high as the
heater support leg.
c) start the dishwasher, let it fill and start to wash, add 24 to 32 oz.
(pitcher of hot water), to the tub and let it run through the wash cycle, then
check for a better wash performance.
We could have been a bit more exact, but you forgot to include a model number, but you’ll have it taken care of with these general checks.
Good Luck,
