washer will not spin.
My washer agitates, but after washing water will not spin out. Can this be a fuse/ I checked the belt and it’s good. I also check the pump and it’s good. Please help me, what do you think it is?
The most common cause of this is a worn thrust bearing. It is responsible for relasing the brake. When it wears, the brake doesn’t fully release. It’s part number 24 in this diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48142&diagram_id=672729#d672729
AP4009132
