Washer won't agitate,spin,or empty
Kenmore 110.25842400 fills but won’t agitate, spin, rinse or empty. I ahve tried all the seetings on the timer to no avail. Help please!:slight_smile:
I have The same model & had the same problem. The timer would not advance. The problem was caused by a defective lid switch.
If the motor makes a noise, then silent, you have something stuck in the pump.
