washer won’t finish cycle, soin or drain hold lid swith down it cliks then it will work sometimes, moved timer to spin or drain the timer makes a buzzing noise. so timer going bad or lid switch?
Open the control panel (the instructions are attached). Unplug the lid switch harness plug and using an insulated piece of wire bypass the lid switch.
Run the washer on spin/drain cycle.
If it will work, replace the lid switch.
- The lid switch AP3100003
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264792
gene thanks so much it works like a champ!!!
thanks gene works great!!!
You are welcome. I’m glad it’s up and running.
