Washer won't do anything but fill
My Maytag washer will only Fill. The timer sounds and looks like it is working properly. The Lid Switch is functioning properly as I took it apart and it stops the timer. I didn’t jump it out since it stops the timer when actuated. Other than that it doesn’t make any noises. No humming etc. Is my motor bad? Is there a relay in the timer that is not picking?
