The water from the washing cicle remains in the tub. I can hear the timer and see it moving to the end. If I drain it manualy by lowering the hose to the floor, the spin cicle workes fine. I had a similar problem 18 months ago and found out that it was the pump. I replaced it, and it worked fine till a few days ago. I bought another pump and the problem remains the same. Any suggestions?
Check the lid switch.
— Begin quote from ApplianceJunk;642956
Thanks for responding AJ. If the switch works during the wash cycle, can it still be responsible for not working the drain? What do I look for to see if is defective?
