washer works only in rinse cycle
In wash cycle nothing happens - no water no noise, but if I advance to the rinse cycle it works fine. Is this the timer or what?
If the machine will go through a complete rinse cycle, fill, agitate drain and spin then this suggests there is nothing wrong mechanically and that the problem is your timer.
Go ahead and replace it, and if you order it from this site and that is not the problem you can return it.
