Washer drains after wash cycle then won't fill for rinse
Washer works until after the spin cycle of washing then when it’s time to rinse you can hear humming but no water fills.
If this happens on all selection cycles it could be a lot of things, but I would first replace the timer and see if that fixes things.
If you buy from this site and a new timer does not fix the problem you can return it.
