Washer
I have a probem with my washer. This is intermittent and does not happen everytime. When I set the washer at the beginning of the wash cycle to fill the tub, sometimes the water just continues to drain out. Then I usually have to turn the knob to the spin cycle, let it spin and then start all over again. I had this happen once before but it was in the rinse cycle. I started the wash and when I went back to check, this is when I noticed that the washer has been stuck on the rinse cycle as the tub will not fill, just kept draining.
Can this be the timer?
