washer is not spinning when draining. put in new timer and still not working. i can push on/off and it will kick in and spin. took door switch out and wired together to eliminate that. Help!
Hi.
What is the complete model number?
Simon.
model # 100.22722110
Hi.
Why did you bypass the lid switch? Did it make any difference?
This washer is equipped with "neutral drain transmission", witch means that washer first draining the water out then timer pausing for a few seconds allowing transmission gears to engage. When the motor restarts - the basket start spinning.
Check if the timer makes a brief stop when it’s draining.
If it’s not pausing - bad timer.
Thank you.
Simon.
Will check that. I just replaced timer with new from you guys. It is better than with old timer. Thanks, will let you know
You are welcome.
Simon.
Simon, washer paused for 3 seconds then kicked to spin but didn’t stay engaged. Shut off and turned right back on and started to spin and drain. Same after rinse cycle.
Hi.
Does the washer spin and drain? Does the laundry ready for the dryer at the end of the wash?
Do you still have the lid switch bypassed?
Simon.
Yes, it will spin and drain. It doesn’t spin after wash or rinse unless I push timer off then on. Will spin at end of cycle. I do still have lid switch by passed.
Hi.
Please double check the model number and post the timer part number that you replaced.
Thank you.
Simon.
Simon,
Washer model # 100.22722 100, ser.#1807047, type 111. Old timer part#3955349 (Invensys). New timer part#WPL 661649.
THANKS
Hi.
The model number probably is 110.22722100. If that is correct then the timer part number is good.
As far as the problem is I still think it’s the timer because you are able to engage the spin manually, by stopping the timer. This illuminates the transmission.
Try another timer.
Thank you.
Simon.
Thanks. I just got this timer from you guys. Is it warranted?
You can return any unused parts even if they been installed.
Simon.
