Hi,
My Maytag washing machine has begun shutting itself off after filling with water. I have to turn the machine off, and move the dial into the washing cycle to get it to start aggitating. It then stops again half way through the wash cycle. It will not go through the rinse cycle at all, I have to manually put it into the spin cycle to get the water to drain off. Do I need to replace the timer or is it another part that I need to replace? Thanks for your help.
