water leak at fill
I have a washer leaking water at fill. It appears to be spraying from or at least near the water inlet valves. How do I remove top and or back to get a better look?
You have to remove the washer cabinet. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KAWS750JQ4 | AppliancePartsPros.com
