water leak under door area
I’m trying to track down a leak from the bottom door area, replaced door gasket but still leaks. It seems like maybe the water level switch may be leaking also ! , am I on the right track to replace the water level switch and the float which may cause the leak by over filling the tub? thanks in advance to any response Greg
I see 148 looks but no opinion on leak,is it possible the new gasket is’nt fitting ? i’m not looking for answers, maybe some opinions
— Begin quote from Grizbee;647105
In case anyone else is having this problem ,i found the answer, so simple. After spending $50 for door gasket,and still leaking, I asked the parts salesman for any bulletens on this problem and he told me to check the o-ring on the rinse-aid dispenser and yes this part costing less than $4 stopped the door leak !!! thanks to the guy I can’t remember your name!
