leaking water
I have water leaking at door bottom, and I thought the only source of leakage would be the door gasket which I bought and replaced. the unit is still leaking from the door bottom, so I wondered if there is a way to adjust or tighten the seal with a latch adjustment or could there be another source of water penetration in the door itself. also what does the water deflector do? can i solve a problem by replacing this also?and finally is there a way for water to leak on the float for the water level control switch? seems to be adrop of water coming from there also, hope this isn’t tooo many questions, thanks in advance Greg
