Water tube connector
I must replace the single-port, dual solenoid water control valve because it started leaking. My house water supply line connects to this valve using brass not, compression fitting. The water tube "coming out" of this valve is inserted into the valve using an palstic orange fitting that resembles a thick washer. How do I discinnect and reinstall this line/connection? Do I need to relaoce the ornge washer thing?
Picture below.
Thnx for any help.
