New Advice
I just bought a new dual water valve assembly (ice maker and indoor water) and it has compression fitting to this. May question is how do you diconnect the old unit along with the water lines and hook up the new one. Thanks
Push in the central collar while pulling out the plastic tube.
Push the tube into the central collar on the new water valve.
