Whirlpool Accubake - Fans won't stop & F2 E1
Whirlpool Accubake RBD306PDB - Ran self clean on top and then bottom, blowers will not stop running…days later. No error codes received, self cleanings both finished without any events. Ovens both worked fine, but blowers continue running. I have checked the internal oven temp sensors and resistance is correct. Checked thermal fuse on control board. Can’t find any problems. After reassembly, now receive F2 E1 and only couple buttons are working. Any thoughts on blowers and/or buttons?
Sounds like the cause of the first problem (non-stop blowers) is a bad control board.
The "F2-E1" error code means "Keypad keytail not connected".
It can be:
  1. Loose connection at the control board
  2. Bad connector on the board
  3. Hairline cracks on the control panel ribbon cable tracks
The ribbon cable can be inspected visually with a magnifying glass.
I would replace the control board first and see how it’ll work.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265348
