whirlpool cabrio
unbalanced load occurs in every wash cycle regardless of load size washer has been levelled and balanced any ideas?
— Begin quote from tomastom;489009
Tomastom,
Have you run a full,short cycle, with the washer empty ?
There are several possibilities, that would cause the UL code, and off balanced load. Improper loading, tub not floating properly, bad RPS assembly, etc. You may want to raise the top of the washer and check the suspension rods and joints for debris and stiffness.
Good Luck,
